Discussion topic: Tried to transfer old number & failed. OAP needs help
This message was authored by: Pat115
I joined Sky with a new sim.
Activated SIM and went to change to my old number.
I made the request.
Waited
Then inserted the old sim.
I was sent a activation code.
Message said there was an error.
Tried at least 3 times on BH Monday.
It hasn't changed.
As my number is attached to many items, I cannot use the new number.
I need detailed guide on getting my number changed
Or help in cancelling Sky if they won't do it
Re: Tried to transfer old number & failed. OAP needs help
@Pat115
Has your Sky sim activated so is this working ?
Is your number that you want to transfer to Sky currently with a different network ?
When did you give Sky the pac code you got from your other network as you need to do this to move the number from them to Sky as per this:
https://www.sky.com/help/articles/switching-to-sky-mobile-keep-your-number
Activate the sim when it arrives but do not put it in your phone, so keep your current sim in it.
Get pac code from your current supplier
Give Pac code to Sky
When your current sim stops working insert your Sky sim in the phone.
Avatar for Pat115
I did activate the sim
I have a PAYG number for years & no PAC.
The transfer did not ask for a PAC
Avatar for Pat115
  • But in Ireland & link did not open due to my location
You do need a PAC code if if the network is a PAYG one as this is how the number is transfered, so the way to do this is to put that PAYG sim back into your phone then sent the text message (as per what it says on the link I posted above for you) to get the PAC code then you need to give it to Sky.
You can give Sky your pac code online here:
https://www.sky.com/myaccount/mobile/sim/x/my-number/transfer
OK, this is the key bit:
  1. Text PAC to 65075 using your old SIM, not your Sky SIM.
  2. Order your new Sky Mobile SIM.
  3. Activate your Sky SIM online.
  4. Let us know your PAC switching code and the number you want to keep.
Avatar for Pat115
Thanks again.
But attempting to send to 65075 with the message PAC is not working.
I sent a test message to another person & message system is working
In that case @Pat115 with their sim in your phone call that network to ask them for the Pac code.
Avatar for Pat115
Thanks again but I cannot find a Sky number
They don't seem to like talk
Have you now got the Pac code from your other network as it is them you need to call to get it. If you have got it then with the Sky sim in your phone you can call Sky by using the 150 (just that) number and say nothing when asked any questions by the bot.
This message was authored by: twilight+princess
Sometimes you need to text PAC + your birthdate to that number so eg: PAC01/01/2010
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
