Discussion topic: Transferring data and keep phone number
This message was authored by: VALETIA40
If I use my sim card from old mobile and put in new phone will I keep my number
Re: Transferring data and keep phone number
@VALETIA40
You will keep your phone number as the number is linked to the sim itself.
@VALETIA40  Yes you will
Avatar for VALETIA40
Transfer
Hi do I transfer data first before putting in my old sim card thanks
Re: Transfer
@VALETIA40
The data remains on your sim so it doesn't need to be transferred as it will still be available when you put it into your new phone.
