Discussion topic: Transfer from O2 to SKY problems
This message was authored by: Vivienne51
Hi
activated SIm, sent PAC number to O 2 everything seemed okay. Received a temporary number for a day, old number connected within a day.
Now my support worker cannot receive or send to my transferred number or even the temporary one.
not sure why this is happening and I'm hoping this isn't affecting drs and hospital contacts as I I need these 24/7.
anyone got any ideas
thank you
Re: Transfer from O2 to SKY problems
@Vivienne51
Is your phone now showing the correct one in it's settings because if it isn't try changing it.
Avatar for Vivienne51
Level 2 icon
The phone settings says unknown
Level 2 icon
I am not able to change it
What phone have you got ?
Level 2 icon
Google pixel 7 plus
Can other people call you or is it just this one person that is having issues ?
Level 2 icon
I am losing more people by the hour but I can call them
As you can make calls then it might be worth calling Sky tomorrow on 150 so they can look into this for you.
Level 2 icon
Thank you for your help
This message was authored by: twilight+princess
Try a reset of the Network settings.
settings> system> reset options then reset network.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
