Discussion topic: Swap
This message was authored by: AhmadR1
Swap
Hi
I just made an order for an iPhone 16 Pro, but I wanted to use the Swap option which I didn't. So, do I need to cancel my order And go through the swap program or when I receive it I can trade in my older device? I am a bit confused about what should I do know. The thing is I don't want to pay two separate bills when I only use one device
Re: Swap
You will need to call Sky as they will probably have to cancel this order so it can be placed against as a swap order which will mean that you will be credit checked again if this is the case.
150 is the free number to use from a Sky Mobile or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
