Discussion topic: Stuck
Message posted on ‎15 Apr 2025 07:48 PM
Stuck
Message posted on ‎15 Apr 2025 07:51 PM - last edited: ‎15 Apr 2025 09:41 PM
Re: Stuck
If you have upgraded your data on your curremt sim then is your new plan showing on your account ?
Message posted on ‎15 Apr 2025 09:37 PM
Re: Stuck
I suspect you've purchased a new data plan (which will have a new number and will mean you're paying for two).
If you want to change your monthly plan then you can do that once a month from the available rates (which won't be as good as the above additional SIMs).
You cannot (easily) transfer numbers between SIMs.
