Discussion topic: Sky roaming
This message was authored by: SMcC241326
Sky roaming
Is roaming free with sky mobile in Rhodes?
Re: Sky roaming
Hi @SMcC241326  there is no free roaming at this time with sky mobile. After Brexit , Sky started charging £2 for each 24 hours use when roaming in mostly European destinations. Rhodes (Greece) is covered by that charge.
edit. It kicks in automatically when you send a text, make a call or use a small amount of data. Calls to local numbers are charged extra.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Re: Sky roaming
@SMcC241326
Also bear in mind … It's common to pick up a mast from Turkey when in Rhodes. Sky do warn of this. See this link, in particular'accidental roaming' near the bottom...
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
