Discussion topic: Sky mobile
This message was authored by: Shannon123
Sky mobile
Hi, I'm thinking of getting a device through Sky mobile. However, I want to continue using my sim with o2 so just want the device. It doesn't let me not select a sim on checkout. I've been told that I can just not use the sim but do I select a plastic sim or an e sim on checkout if I won't be using it ?
Re: Sky mobile
If you can't checkout without a SIM then simply do not activate it - you won't be charged and it will drop off your account after a month.
Re: Sky mobile
Hi @Shannon123  i would select plastic normal sim.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Shannon123
Re: Sky mobile
Hi, many thanks. So i assume id have to select a plastic sim if i wont be activating it?
Re: Sky mobile
If it won't let you proceed with the order without selecting a sim then personally I would select the ordinary plastic sim @Shannon123  and don't activate it when it arrives.
