Discussion topic: Sky mobile
This message was authored by: Phil212
Sky mobile
My sons phone is saying emergency calls only
Re: Sky mobile
Does it still say this if you turn it off and back on again, if it does then do any issues appear here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
If nothing appears then you will have to contact Sky, perhaps via social media as there are links at the bottom to their sites as they might want to send you a replacement sim to try.
Avatar for Phil212
Level 0 icon
Re: Sky mobile
Tried turning it off and on nothing saying emergency calls on
