Discussion topic: Sky mobile not working abroad
This message was authored by: Max50
Hello. I have landed abraod and my phone is not working. I cannot make calls and my mobile data is not working. I can use WiFi but that is it
Re: Sky mobile not working abroad
@Max50
Can you tell us where you've gone?
Is your phone set to automatic or abroad in its sim settings or app ?
Avatar for Max50
Budapest
Avatar for Max50
It was then I changed it to partner and that just took all signal away
Avatar for Max50
When I change it it just says no service. My partner is experiencing the same thing
