03 Mar 2024 11:53 AM
In the last two weeks, Sky Mobile has stopped working for me and my partner in Jersey. I have gone from having 4g all over the island to nothing, and am now unable to send or receive calls/ texts and rely on wifi for internet... quite frustrating to say the least!
I've tried all of the recommended troubleshooting methods on the Sky guide and have contacted support, they tell me it has been escalated to the network team and I could expect a response in 2 days (this was 4 days ago) and have received nothing back, I have been chasing daily... quite disappointing customer service
I am wondering if anyone has any additional tips, or can escalate this for me further
03 Mar 2024 11:57 AM
Posted by a Superuser, not a Sky employee. Find out moreHi @ElsworthC0105 just checking you have tried connecting to a different local network ?
03 Mar 2024 11:59 AM
Hi @63johnw, yes I have tried using manual network selection - sure, Airtel Vodafone and JT, all unfortunately not working, which has led to me thinking it's an issue with sky vs a local carrier (as they are still working for others on the island)
14 Mar 2024 01:35 PM
Sky mobile customer s unable to connect to jersey networks for two days any advise grateful
14 Mar 2024 01:57 PM
Posted by a Superuser, not a Sky employee. Find out moreDoes any network issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
14 Mar 2024 02:51 PM
Unfortunately Jersey not being recognised to check networks
It is not usually a problem to use our data nd connect without an issue
14 Mar 2024 09:25 PM
Unable to roam with sky data in Jersey channels islands for the past two days
15 Mar 2024 02:17 PM
Hi wondering if you are still having problems roaming in Jersey we are now 3 days unable to connect , previously no issues usually connect to
JT grateful if you have any info to help resolve I have reported
16 Mar 2024 05:32 PM
unable to connect to any Jersey networks for days .
usually no issues with roaming escalated but no updates
anyone else have any issues ?
thanks
17 Mar 2024 10:15 AM
Also have the same issue. Have contacted Sky numerous times but no use. Have travelled away from Jersey and has worked fine. Has been like this for four weeks now. Any solutions welcome. Thanks
17 Mar 2024 10:16 AM
Yes. Had this issue for 4 weeks. Sky don't seem to be able to solve the issue. Never had any problems before.
17 Mar 2024 10:22 AM
Hi thanks for your reply ! Helpful to know it's not just us , this has been escalated numerous time ms but no one seems to be able to help ! Or understand where Jersey is 🥴
17 Mar 2024 03:25 PM
Posted by a Superuser, not a Sky employee. Find out moreHi, anyone using an iPhone ? Try going to settings, mobile service, sim applications and try changing the setting in there.
17 Mar 2024 03:56 PM
unfortunately this still does not allow us connect to any network here
18 Mar 2024 07:45 AM
