Discussion topic: Sky Swap Question
This message was authored by: Benzy
Sky Swap Question
Bought a 15pro from sky last year, after a month it developed a fault so i i took it to apple and they diagnosed a fault with the logic board and replaced the handset.
Would this effect my ability to upgrade through the sky swap scheme as i am sure i read the serial numbers on the handsets need to match?
Re: Sky Swap Question
Hi @Benzy  i dont think it should affect it but you could ring sky on 150 and ask them to change the IMEI number of the device on your account.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
