Discussion topic: Sky Mobile data usage
This message was authored by: Alvor123
All of a sudden we are running out if mobile data why.
This message was authored by: daveNOS
Re: Sky Mobile data usage
@Alvor123 That will be down to one or more apps using data, you would have to look on your device to see which app/apps are using the  most, Sky wouldn't be able to tell you why your using more.
