Discussion topic: Sky Mobile Roaming
This message was authored by: Mt52
Sky Mobile Roaming
Does the new free roaming  for diamond customers cover all numbers/ sims that are included on the main account/ overall monthly bill
Re: Sky Mobile Roaming
@Mt52
Yes, all sims on the account are covered by it.
Don't forget @Mt52 that data is still limited to 25GB per billing period otherwise you will be paying per GB for what you use over this.
Also be aware it's not all countries @Mt52, there are 120 included.
All Opinions Are My Own
Avatar for Mt52
Level 0 icon
Thankyou, another question off the back of this then , if 25gb is reached can you then use the £2 daily passport ( hypothetical question but I have a teenage daughter on my account!)
@Mt52
No. See this link
https://www.sky.com/help/articles/sky-mobile-fair-usage-policy.
Roaming using Roaming Passport Plus is now limited to 25GB per billing period.
From Skys own website...
When you roam using our Roaming Passport Plus, we consider that up to 25GB per billing period is a reasonable amount of data to use. If you exceed this amount, we'll assume that you're no longer using data in the way expected of a reasonable customer for periodic travel.
We may suspend your service, restrict your usage, or charge you for the data that you use in excess of these amounts (currently £2.50 per GB), and we'll let you know by SMS or email before we do so.
