This discussion topic has been answered Discussion topic: Sky Mobile Help
Message posted on 25 Oct 2025 09:35 AM
Saturday morning, every number I try to call to get help is just a robot that tells me the lines are closed.
Having major problems with my Sky mobile esim, so I went ahead and deleted it thinking I could easily reinstall it.
That was a massive mistake.
The QR code in the app is no longer active.
So great I'll just order a replacement esim, should be handy and easy enough right?
NO
Sky needs to send me a security code to continue on the option and guess where they need to send it too?
You guessed right, my mobile number.
How can one get this code if they DON'T have an active esim?
Make it make sense.
So due to my stupid idea to delete and simply reinstall my esim, I am bang smack out of luck, and have to wait until Monday to fix.
That security check really needs another look at, oh you want to replace your esim, fine but we need to send you a text first! What??
Thanks Sky, no calls or data for the weekend. Great service with plenty of help for scenarios like mine.
10/10
Message posted on 25 Oct 2025 09:53 AM
Hi @Robert186 they should be able to send the code via email, others on here have reported that. If you can't get through on the phone try the social media links at the bottom of this page.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 04 Nov 2025 10:17 AM
Re: Sky Mobile Help
I am having this exact issue. I tried to manually install a new eSim while I could access wifi, but it didn't complete activation. Have reset everything on my phone, can't email customer service...
Message posted on 04 Nov 2025 10:20 AM
Re: Sky Mobile Help
Reach out to the team via Instagram, it helped me so much. They tried everything to get me back up and running.
Unfortunately I had to end up getting a physical sim posted to me but the support I got was brilliant.
Message posted on 04 Nov 2025 10:22 AM
Re: Sky Mobile Help
Try the social media links at the bottom of this page @nsd1 to see if they can help you.
Message posted on 04 Nov 2025 10:24 AM
Re: Sky Mobile Help
What a nightmare - I am on a work computer and can't access social media.
