Discussion topic: Signal problem
This message was authored by: Signal3
Signal problem
I get no signal at home and have always had problems with sky.
Re: Signal problem
Hi @Signal3  any issues showing ?
https://www.sky.com/help/articles/service-status-sky-mobile
it could be you live in an area of poor signal and until the network is upgraded there will be little you can do.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Re: Signal problem
@Signal3
Does any relevant information show on this link?
It may disclose a nearby mast issue. In case you aren't aware Sky don't own or maintain any mobile masts so if there is an issue you and others in the area will be relying on a third party fix.
This message was authored by: SB124
Re: Signal problem
I currently have no signal where as I usually do. A satellite/sos icon was showing
Re: Signal problem
@SB124
See the post immediately above yours.
