Discussion topic: Signal issues
This message was authored by: Olivia2411
Signal issues
I usually get really good reception at home and round the village we live in. But since Wednesday I have had no signal (my husband on O2 hasn't either or my in laws who live near by on Tesco). How can I investigate if there is a problem? When I check via the service checker it says we have good service in our area.
 The WiFi is really slow so we rely on our mobile data so it is very frustrating
Re: Signal issues
Hi @Olivia2411  is this the one you used ?
https://www.sky.com/help/articles/service-status-sky-mobile
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Re: Signal issues
@Olivia2411
Is any relevant information showing on this link?
It may disclose a nearby mast issue. In case you aren't aware Sky don't own or maintain any mobile masts so if there is an issue you and others in the area will be relying on a third party fix.
Avatar for Olivia2411
Level 0 icon
Re: Signal issues
I’ve checked via that link and it says we have good service. Not sure what to do now. Thought it might fix itself but we're on day 5 now
Level 0 icon
Re: Signal issues
I've reported the problem now! Thank you for your help! Xx
Re: Signal issues
@Olivia2411  The fact several people are having issues would indicate a network issue. Anything showing on this link (sky use the O2 network).
https://status.o2.co.uk
Re: Signal issues
As do Tesco Mobile, so that's probably a clue.
