Discussion topic: Roaming
This message was authored by: MrsO79
Message posted on 14 Oct 2025 09:22 PM
Roaming
Does sky roaming only charge you if you are still abroad and using data? Or does it charge you as long as it's activated on the phone?
Find out more
Message posted on 14 Oct 2025 09:31 PM
Re: Roaming
You should only be charged when you are abroad so that will either be £2 per 24 hours use or is some countries you are charged for for what you actually use. Roaming charges do not apply when in the UK.
