Discussion topic: Roaming
This message was authored by: mOshi
Message posted on 22 Dec 2024 09:59 PM
Roaming
How can I activate my roaming while I am already in abroad
Find out more
Message posted on 22 Dec 2024 10:09 PM
Re: Roaming
Hi @mOshi it starts automatically once you send a text, make a call or use a small amount of data. Just make sure roaming is active in your phone settings. Make sure your spend cap is set high enough for the country you are in.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Find out more
Message posted on 22 Dec 2024 10:28 PM
Re: Roaming
Also make sure your device is seto to abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
