Discussion topic: Roaming passport
Message posted on 07 Feb 2025 10:58 AM
Roaming passport
Message posted on 07 Feb 2025 01:09 PM
Re: Roaming passport
Do you have a spendcap set as while you do not have to if you do it has to be set high enough to cover your stay.
Also make sure this setting is set to Abroad:
Apple:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
Message posted on 07 Feb 2025 01:18 PM
Already tried,still the same .
Bouncing from one WiFi hot-spot too another.
Message posted on 07 Feb 2025 02:01 PM
Hi @Old+guy60 try turning off automatic network selection in your phone settings, then do a manual search and try selecting different networks from the list.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
