Discussion topic: Roaming in he caribbean
This message was authored by: Keith-fowler
Can I use roaming in the Caribbean and what are the charges
Re: Roaming in he caribbean
You can check the charges yourself here as nit all countries are covered by the £2 daily charge so using your device in those countries could see you landed with a large bill:
https://www.sky.com/help/articles/sky-mobile-roaming-destinations-and-charges
Avatar for Keith-fowler
What about on board a cruise ship between islands
This message was authored by: daveNOS
@Keith-fowler The rates for which ever country your phone connects to will apply, that is of course if your close enought to connect if not you won't be able to use your phone unless you use the ships wifi and that will be expensive.
That is covered on the link I posted at the bottom.
@Keith-fowler
Only the very rare overseas territories of European nations will be covered by £2 roaming.
When on ship, you are restricted to whatever high price the cruise company charges per megabyte for WiFi because this has to travel over a satellite link.
