Discussion topic: Roaming data
This message was authored by: ELIZABETHPRINCE
Roaming data
Like to remove the cap, so I can have free roaming
Re: Roaming data
@ELIZABETHPRINCE
Free roaming in 120 selected countries has nothing to do with your spend cap as this is available if your VIP level is Diamond as you can read about here:
https://www.sky.com/help/articles/free-global-roaming-diamond-vip
Re: Roaming data
You'll have to explain in some more detail what you're after as certain caps cannot be lifted, e.g. the 25GB fair usage limit.
Re: Roaming data
@ELIZABETHPRINCE
Perhaps note that removing a spending cap is very unwise unless you are certain the location you are in is covered by the free or £2 roaming and there's no chance a signal can come across a border from somewhere which isn't.
