Discussion topic: Roaming data
Message posted on 15 Sep 2026 10:16 AM
Roaming data
Message posted on 15 Sep 2026 10:22 AM
Re: Roaming data
Free roaming in 120 selected countries has nothing to do with your spend cap as this is available if your VIP level is Diamond as you can read about here:
https://www.sky.com/help/articles/free-global-roaming-diamond-vip
Message posted on 15 Sep 2026 10:26 AM - last edited: 15 Sep 2026 10:27 AM
Re: Roaming data
@ELIZABETHPRINCE wrote:
Like to remove the cap, so I can have free roaming
You'll have to explain in some more detail what you're after as certain caps cannot be lifted, e.g. the 25GB fair usage limit.
Message posted on 15 Sep 2026 10:28 AM
Re: Roaming data
Perhaps note that removing a spending cap is very unwise unless you are certain the location you are in is covered by the free or £2 roaming and there's no chance a signal can come across a border from somewhere which isn't.
