Discussion topic: Roaming charges
This message was authored by: Holly104
Roaming charges
Hi, I'm in Thailand, and on the way only used my phone with free WiFi on planes. I didn't use my phone in an airport etc.
however, I've incurred a bill of £45 for data roaming charges. How can I contest this?
Re: Roaming charges
Unless your phone was correctly configured not to roam then you've probably been correctly charged.  (It's obviously connected to the local cellular network)
Modern smart phones use data in the background.  Thailand is 36p per MB and can be used quite quickly.
Of course, you can contact Sky to dispute it.
Going forwards, if you intend to use WiFi only then put your phone in flight mode.  (This will ensure no cellular is used but you can still connect to WiFi networks)
