7
This discussion topic has been answered Discussion topic: Roaming charges
This message was authored by: Higger
Roaming charges
Been charged roaming on holiday with data turned off  ?
This message was authored by: PandJ2020 Answer
Re: Roaming charges
Which country?
Calls can incur charges (including incoming).
Re: Roaming charges
Which country?
Avatar for Higger
Re: Roaming charges
West Indies
Re: Roaming charges
Did you make any calls or send any text messages ?
When did you turn off roaming and data, was it before you left the UK ?
Re: Roaming charges
It's a rest of world location - so charges can be incurred aside from data.
Re: Roaming charges
Hi @Higger  as well as what others have said if you waited until arriving before turning off data and roaming then the phone will have connected to the local network and immediately started using data which would incur charges.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Higger
Re: Roaming charges
No calls or messages at all was on flight mode then turned off data roaming
Re: Roaming charges
It must of connected to the local cellular network - otherwise, how would they know you were there to incur charges?
Call Sky on 150 to query it.
