Discussion topic: Roaming Blocked
This message was authored by: Sunam1
Roaming Blocked
In Spain, was connected to Movistar and it worked in a fashion since we arrived. However, today my wife and I are getting the following message when we try to connect to Movistar " your sim card does not allow connection to this network". Our account is paid and up to date. Any help please. Thank you.
Re: Roaming Blocked
@Sunam1
Are your phones both set to abroad:
Iphone:
Settings > Mobile Service > SIM Applications > Make sure this is set to Abroad..
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
If they are try searching for other networks to see if they will connect to a different one.
Avatar for Sunam1
Re: Roaming Blocked
The roaming tab is on/blue.
The access point names is set to:
4G.tele2.se
MCC 240
MNC 07
APN TYPE Default
Apn Protocol IPv4
 I haven't adjusted anything and can't understand why we blocked from Movistar connection.
I have an O2 UK phone connected to Movistar working fine.
