Discussion topic: Replacement sim help
Message posted on 07 Sep 2026 11:17 AM
Hello, After nearly losing my phone recently, I wish to prepare for if this happens for real. I will get a cheap phone and transfer all my data over, then basically leave it in a cupboard until I need it.
I believe that if I request a replacement sim to retain my number, but use it in the back up phone it will deactivate my current sim. So my question is, if I order a replacement sim now, is there any time limit on activating it or can I leave it in the pack until I need it, bearing in mind this could be years?
Message posted on 07 Sep 2026 11:24 AM
Re: Replacement sim help
I believe that if I request a replacement sim to retain my number, but use it in the back up phone it will deactivate my current sim. Correct
So my question is, if I order a replacement sim now, is there any time limit on activating it or can I leave it in the pack until I need it, bearing in mind this could be years? No, as the sim will dropp off your account after approx 60 days.
Message posted on 07 Sep 2026 11:34 AM
Thank you so much for your help 👍
