Discussion topic: Received call cuts out when I answer
This message was authored by: Blumist
I answer an incoming call, after saying 'hello'; the caller says 'hello', I say 'hello, can you hear me' then the line cuts out.
This has happened many times, the latest being when the hospital where I am receiving treatment called. Obviously, if the hospital calls it must be urgent.
I need to know why the hospital called!
Ineed to know why my calls cut out everytime received.
Re: Received call cuts out when I answer
@Blumist
Have you reported this to Sky because at the very least they might want to send you a replacement sim to try.
Avatar for Blumist
Thanks for reply, am trying to contact Sky, but as we know it's difficult to get through to the correct department. Will keep trying tho.:)
