Discussion topic: Problems with roaming
This message was authored by: Better2021
Arrived in Milan and my sons iPhone 12 had roaming for about 10 mins then it went off. Now can't get roaming or even make calls with WiFi. Any suggestions would be appreciated. Thanks
Re: Problems with roaming
@Better2021
You could try turning off automatic network selection in the settings then get your phone to search for other available networks to see if it will then connect and allow you to make calls. Also make sure the spend cap hasn't been reached if you have one set.
Although you don't have to, do you have a spend cap set because if you do it needs to be high enough to cover your stay.
