Discussion topic: Problem with I message after number ported
This message was authored by: Lyns05
I ported my number from EE yesterday the number is correct in my number. I cant send i messages its sending them from my email and the number just has the cog spinning around and says verifying. Ive tried re setting network settings switching off and on multiple times turning off imessages and facetime etc. When i try to untick the email and select the number it says activation error. Any ideas? Will this just correct itsself in a few days? My husbands was doing the same but his is fine this morning and he didnt try any of the fixes just left it to do its thing.
Re: Problem with I message after number ported
@Lyns05
What phone have you got ?
Avatar for Lyns05
Hi Its an iphone 11
@Lyns05
Give this a try:
https://support.apple.com/en-gb/101744
Avatar for Lyns05
tried this it shows the number but wont let you select it as just has a cog going around saying verifying and wont let you select it
Have you tried a reboot of your phone ?
Avatar for Lyns05
yes off and back on reset network settings and reset phone settings still not working.
