Discussion topic: Phone
Message posted on 07 Nov 2025 11:50 AM
Phone
I want to change over from o2to sky. Can I talk to a human being on the phone or do I have to do everything online myself?
Message posted on 07 Nov 2025 12:09 PM
Re: Phone
@Lol+cam Y
ou shpuld be able to order online yourself, if you need to speak to someone you'll need to call, these are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
Message posted on 07 Nov 2025 01:05 PM
Re: Phone
Yoy can order a Sky sim here by selecting a plan for it:
https://www.sky.com/shop/mobile/plans
This link explains how to get a pac code and then give it to Sky once you have activated your sim:
https://www.sky.com/help/articles/switching-to-sky-mobile-keep-your-number
Buy the Sky sim
Activate the sim when it arrives but do not put it in your phone, so keep your current sim in it.
Get pac code from your current supplier
Give Pac code to Sky
When your current sim stops working insert your Sky sim in the phone.
You can give Sky your pac code online here:
https://www.sky.com/myaccount/mobile/sim/x/my-number/transfer
Message posted on 09 Nov 2025 08:42 AM
Re: Phone
I was hoping there was a number I could call to talk to an actual human being! I'm terrible with ICT! If I have a problem further down the line too od imagine it would be a nightmare. I dint want to text with AI
Message posted on 09 Nov 2025 09:25 AM
Re: Phone
@Lol+cam wrote:I was hoping there was a number I could call to talk to an actual human being! I'm terrible with ICT! If I have a problem further down the line too od imagine it would be a nightmare. I dint want to text with AI
Does this help? https://www.sky.com/shop/store-locator
