Discussion topic: Phone signal
This message was authored by: Cm2118
Phone signal
When setting up my phone I accidentally moved my phone number from my physical sim to my eSIM and how would I go about getting that switched back over
Re: Phone signal
Hi @Cm2118  you would need to call sky and ask for replacement physical sim to be sent out. You can't reactivate the old one if it's no longer active.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Re: Phone signal
I may be able to get you some help from here if you would prefer @Cm2118  ?
