Discussion topic: Phone doesn't work in spain
This message was authored by: 1S9A9M0
Message posted on 02 Jun 2025 12:19 PM
Not long landed in Spain and all I get is emergency calls only, gone through all the sky help I can. It then says to call. That's great only I have no network anywhere! Gone through changing all the settings it says, making sure roaming is set (20 times over) And still nothing! Any advice besides ditching sky mobile?
Find out more
Message posted on 02 Jun 2025 01:03 PM
Re: Phone doesn't work in spain
Spain is one of those countries thst roaming issues do seem to crop up so as you have done everything all you will be able to do is to connect to a Wi-Fi connection if available and use this instead.
