Discussion topic: Phone Number not showing correctly
This message was authored by: LaureniPhone
I can make and receive calls from the number I have had for years but since switching to sky from my previous network the phone number showing on my iPhone settings is not correct, and iMessage is not working from my correct number, how can this be resolved?
Re: Phone Number not showing correctly
@LaureniPhone
Try refreshing the network settings so go Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings. Then go to Settings - Phone - My Number and change it if it is wrong, then reboot the phone. You will need to set up your Wifi connection again.
