Discussion topic: Pac code not working
This message was authored by: Gemma166
The pac code provided to myself and my partner is the same pac code.  He has set up his new provider using the pac code however, when I try to set up it does not seem to work.  Should be have both been provided the same pac code or should these be different?
Re: Pac code not working
@Gemma166  Are both phones on the same account if so one pac should do both
if on separate accounts a different pac is required
