Discussion topic: Order
This message was authored by: Veena123
Order
Recency order
Re: Order
Hi @Veena123  do you have a question for your fellow customers here ? This isn't sky CS.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Veena123
Level 0 icon
Re: Order
I want to know about my recent order o don't keno I received email they cancel my order I don't why
Re: Order
Hi @Veena123  if an order is cancelled that is usually down to a failed credit check. You would need to call sky for confirmation of this.
Re: Order
@Veena123
It’s possible you may have failed one of the required credit check(s). For a sim deal it’s just a soft credit check, for a device there’s also an enhanced check. See this link for Skys guidance ~
https://www.sky.com/help/articles/credit-checks-sky-mobile
Be aware that if you keep trying to order the device this could further impact your credit score. If you contact Sky they would be able to confirm that’s the reason your order was cancelled but not why you failed the credit check in the first place as they are not allowed to view your credit record. You would have to sign up to a credit reference agency like Experian or Equifax, which would give you access to your credit record.
Also perhaps check that Sky have the correct spelling of your name.
Any upfront payment you’ve made should be refunded after about 14 days but recent posts suggest it’s taking a bit longer in which case you’ll need to contact Sky to chase it up.
This link may also prove useful
https://www.sky.com/help/articles/sky-credit-builder
