Discussion topic: Not registered on etwork
Message posted on 25 Oct 2025 01:11 PM
Hi there, recently purchased a Samsung Galaxy S25 Ultra which worked fine for a week or so. Message "not registered on network" displayed on screen. I've reset SIM to no avail. Any help/advice greatly appreciated.
Thank you
SeanF
Message posted on 25 Oct 2025 01:19 PM
Re: Not registered on etwork
I take it the phone was from Sky
If so are you able to try the sim in another unlocked phone to see if it works ?
Message posted on 25 Oct 2025 01:26 PM
hi Caesarome, Thanks for your response. I purchased the phone from Amazon (network free). Unfortunately unable to check in other unlocked phone.
Message posted on 25 Oct 2025 01:29 PM
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/mobile
If not then you will have to contact Sky, perhaps via social media as there are links at the bottom of this page to their sites as your sim might have developed a fault.
