Discussion topic: Not receiving verification codes
This message was authored by: Al59
Message posted on 17 Dec 2024 08:23 PM
I've just moved to Sky from EE and transferred my number over, since then I haven't been able to receive verification codes via text!! I've contacted Sky twice and was told I'd hear back within 72hours both times and nothing!!
It's so frustrating I just need to access my apps but can't without the codes!!
I'm receiving normal texts and the odd verification codes but not all!! Any suggestions?!
Find out more
Message posted on 17 Dec 2024 08:49 PM
Re: Not receiving verification codes
It's a fairly common issue @Al59 , check out the following thread:
https://helpforum.sky.com/t5/Sky-Mobile/OTP-not-being-sent/td-p/4573504
