4
This discussion topic has been answered Discussion topic: Not able to make calls
This message was authored by: Christine+Tarvet
Just returned from a holiday in Japan, can't call or receive calls on my iphone16
Re: Not able to make calls
@Christine+Tarvet
If you've very recently returned from abroad try this…
Apple:
Settings > Mobile Data > SIM Applications > Make sure this is set to Home.
Android:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Home.
@Christine+Tarvet
Apple:
Android:
Avatar for Christine+Tarvet
Thank you so much, it worked, you're a genius. Chris
This message was authored by: Nicola20101994
I having the same problem my phone is a iPhone 16 plus and I can't get nothing not even my data and went you call they hand up on you
@Nicola20101994
Have you tried the advice in post 2?
