Discussion topic: No signal
This message was authored by: Beckie+Pegg
No signal
Once again. We have no signal in our area. When is this going to be dealt with, it is happening far too often. Furthermore, no matter where I am, the signal is always very weak.
Re: No signal
@Beckie+Pegg
Do any network issues show here for you:
https://www.sky.com/help/servicestatus/mobile
Re: No signal
@Beckie+Pegg
If there is a nearby mast issue, in case you aren't aware, Sky don't own or maintain any mobile masts so if there is an issue you and others in the area will be relying on a third party fix.
Avatar for Beckie+Pegg
Re: No signal
Ther is a mast issue and this has been going on for a few days this week, and a couple if weeks ago.
Re: No signal
Hi, yes I checked and there is a mast not working near my home.
Re: No signal
It's a pain.  It could be out for days or weeks.
WiFi calling may assist?
Re: No signal
I can't even contact my son using WhatsApp!
Re: No signal
If using WiFi then no cellular connections are used...
Re: No signal
Thanks for your help.
