Discussion topic: No signal after returning from holiday
This message was authored by Cjones This message was authored by: Cjones
I have seen this question answered and I have tried everything suggested (ensuring data roaming is on home, the APN settings are correct, hard reset on phone). I had my phone on airplane mode while away in Mexico as I had access to Wi-Fi throughout the whole hotel. When I came home I turned it off and didn't receive signal, I gave it time then last night spent so long trying everything I've seen suggested, also trying to remove the sim and popping it back in and still having no luck! Any other suggestions will be really appreciated as I'm back to work tomorrow and don't have Wi-Fi when there so will have no way of keeping in contact (also can't believe how common this issue is with sky- definitely needs looked into more)
This message was authored by 63johnw This message was authored by: 63johnw
Re: No signal after returning from holiday
Hi @Cjones  if this is an iPhone go to settings, mobile data, sim applications and change the setting in there.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
@Cjones
Have you checked that your phone is now set to Home as it might still be showing as Abroad.
Cjones
Hello! Sorry I forgot to say it is an iPhone and I have tried to reset the sim application settings both to home and automatic and it has not worked.
thanks for the reply
What is it showing as now and have you tried a reboot ?
Cjones
@caesarome
it is saving as home and still no signal. I have hard reset the phone, only thing I haven't tried it factory reset which i think is my last option.
@Cjones  Do you have another sim you could try in the phone ?
Cjones
@63johnw
i don't unfortunately. I know in past discussions sky have sent out new sims to people who have had this issue so I'll try and get in touch with them to request one. Not ideal.
You can get a replacement here @Cjones  but if it's a phone setting problem that won't help, hence trying another sim if you could.
https://www.sky.com/help/articles/replacement-sim
