Discussion topic: No mobile signal
This message was authored by: Curiousbeever
No mobile signal
Since yesterday I have had no mobile signal in the area I am. Having checked the online help it advises a tower has been removed and an update is expected in January 2026. That does not seem like a suitable amount of time to be without a mobile signal.
area is HX78**
Re: No mobile signal
@Curiousbeever
Sky don't own or maintain any mobile phone masts so if it was 'removed' it was done by a third party. If that's correct then it's beyond Skys control. It seems strange for a mast to be removed without an alternative source being available.
Hi @Curiousbeever  as mentioned that does seem very strange. You may consider putting in a formal complaint.
https://www.sky.com/help/articles/how-to-make-a-complaint
in the meantime you could try setting up WiFi calling so you can still use your phone at home ?
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Avatar for Curiousbeever
The wording is "We have removed a mast" so not sure what to think.
