Discussion topic: No data when roaming in Canada
Message posted on 03 May 2025 12:31 AM
I had roaming when arrived in Ontario Canada Tuesday 29.04
Today 02.05 at local lunchtime it went off
Message posted on 03 May 2025 02:06 AM
Re: No data when roaming in Canada
I've arrived in Vancouver today and haven't had an signal since I arrived.
Message posted on 03 May 2025 07:18 AM
Hi @Pete150 and @KarlaH04 it could well be a local issue. If your spend caps are set high enough then you could try turning off automatic network selection then do a manual search and choose networks from the list. Sky have no control over foreign networks.
I AM NOT A SKY EMPLOYEE
All Opinions Are My Own
Message posted on 03 May 2025 07:57 AM
I have same issue. How do you turn off the network?
Message posted on 03 May 2025 08:00 AM
And what would be high enough for spend cap? I've set mine at £40? Would that be enough?
Message posted on 03 May 2025 09:51 AM
@Ted21 wrote:And what would be high enough for spend cap? I've set mine at £40? Would that be enough?
Yes that should be enough to cover 20 days roaming @Ted21 be aware that calling local numbers isn't covered by the £2 daily charged and would eat into your spend caps.
what phone are you using ?
Message posted on 03 May 2025 09:54 AM
@Ted21 wrote:I have same issue. How do you turn off the network?
If it's an iPhone @Ted21 go to settings, mobile service, network selection and toggle off the a list of available networks should appear. Try these. There are others reporting issues in Canada so there could be an issue out of yours or Skys control.
Message posted on 03 May 2025 02:14 PM
Thanks for your reply.
Still no signal today. I've tried turning off automatic network selection. It gives me 4 network options and I've tried them all but still nothing!
Message posted on 19 Oct 2025 07:08 PM
I'm getting the same thing today. Have tried all the suggested fixes and nothing is working.
Did anyone get a solution that worked?
thanks.
