Discussion topic: No connection to Network since 1 September
This message was authored by: AliF23
I haven't been able to connect to sky mobile network for a week now it's says I am not registered to network.
Re: No connection to Network since 1 September
@AliF23
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/mobile
If not then you will have to contact Sky, perhaps via social media as there are links at the bottom of this page to their sites. They might want to send you a replacement sim to try incase the one you have got has developed a fault,
Avatar for AliF23
It says there is a problem with 5G but everything else is OK.  This is not correct it have not been able to connect for a week and no info or help from Sky.
@AliF23
Have you applied the 5G add-on?
Avatar for AliF23
  • What is this, and if the mast is having an issue with 5G what would be the point?  It says there are no issues with 4G in my area, but there is, nothing is working and hasn't been for a week now.
@AliF23
https://www.sky.com/help/articles/sky-mobile-5g
Avatar for AliF23
Thank you, but as stated i do not have 5G coverage in my area.
Your only option is to contact Sky about getting a replacement sim sent to you.
This message was authored by: Fizzelle
Same issue - now awaiting new sim after all troubleshooting failed. Not clear why this has happened
Avatar for AliF23
I have been told its a local mast issue, but why would that affect me if im going to Manchester or somewhere away from my area?
This message was authored by: Mdl82
Hello I had this issue also. After lots of different troubleshooting I accidentally went into my 'sky menu app' and pressed the roaming button. I think it changed it to automatic. This solved my issue straight away. It could be the same for you.  Sky menu is a different app to sky account.  If you search for it on your phone it should pop up. Give it a try.
This message was authored by: kjb82
no inernet connerction to my phone
