Discussion topic: No calls or Mobile Data
This message was authored by LeighD63 This message was authored by: LeighD63
Hi Guys,
Phone is saying 'No Service' all morning - same issue yesterday all afternoon but did come on yesterday evening. Two friends are experiencing the same issue - is there a problem with Sky Mobile??
Re: No calls or Mobile Data
@LeighD63
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
This message was authored by Anonymous This message was authored by: Anonymous
I don't see to have any problems. As said above it is probably a mast issue. Is the weather not great for you? That usually disrupts signal too. Did you try to turn on Airplane mode on and off after a few seconds? What about restarting your phone? If its still a problem you could always contact Sky through their chat, as assuming you couldn't phone them but you could try that too! Hope you get it sorted!
This message was authored by Ddddania This message was authored by: Ddddania
Mine is the same. No service all morning. Annoying because I can't phone them because can't make calls.
Yeah, understandably its annoying. It might fix itself on its own but if it doesn't do definitely contact Sky support.
This message was authored by TTMODELL This message was authored by: TTMODELL
This is a persistent problem across all my phones even in central urban locations that has got steadily worse in last month. Like many others, I will have to change to another network if this degraded network issue is not sorted soon
I just joined Sky Mobile so hopefully it'll go fine for me. As Sky Mobile runs on O2 they are usually to blame for the bad signal and whatnot, although Sky can also be held accountable. I'm not sure why Sky decided to go with a carrier that is so oversubscribed to the point of mobile data not being reliable. Hopefully you'll get it sorted.
