Discussion topic: Network connection in USA
This message was authored by: neilferguson1
Samsung Galaxy A70
On list as compatible VoLTE etc
Roaming on,  Volte calls SIM1 on and mobile data obviously on.
Arrived in USA and unable to connect at all.
Have no spend cap , so that not issue
Using Scan Network Operators option phone displays
T Mobile and Verizon ,,Neither works, message is " unable to connect try later " or " sim cannot connect to this network"
Sky support have escalated matter but not heard from them, need it working now ..Any ideas
Re: Network connection in USA
Is this app set to abroad:
Sky Menu App or SIM toolkit > Roaming > Make sure this is set to Abroad.
Whilst no spend cap should work, have you tried setting one?
Avatar for neilferguson1
Thanks for reply but in sim toolkit I don't have a roaming option
