Discussion topic: Need help with sky mobile
This message was authored by: StephDoh
I really need help, I changed to sky mobile over a month ago, my phone won't allow me to send normal text messages to any number. It also won't call certain numbers. I have tried everything I have even been on to sky on what's app and I've done all they asked, rebooted the network, turned phone off, aeroplane mode on and off, has anyone else experienced this? I picked the E Sim option when I changed over
Re: Need help with sky mobile
Any mast issues showing: https://www.sky.com/help/articles/service-status-sky-mobile
@StephDoh
What phone do you have and is the correct number shown via settings > phone ?
Avatar for StephDoh
Level 0 icon
I have the new IPhone 17 pro max, yes it's showing my number twice, I'd presume it's because it's ESIM? P1 and then my number and then it has P2 and my number again. I am on P2 for Sky as P1 has no network. It is so frustrating
Avatar for StephDoh
Level 0 icon
Hi how do I check this on the ROI app?
@StephDoh
There is nothing you can check on the MySky app regarding this so if you are unable to call them perhaps try using social media to get in touch with them.
