Discussion topic: My mobile data has a problem. For some reason, it’s running out too quick
This message was authored by: AKani
Message posted on 01 Sep 2024 07:32 PM
My mobile data has a problem. For some reason, it’s running out too quick. I know I am not using as much as that. I have WiFi at home.
Find out more
Message posted on 01 Sep 2024 07:42 PM
Re: My mobile data has a problem. For some reason, it’s running out too quick
When you are at home make sure mobile data it turned off and only turn it on when you are going to be going online when you are out and about. When mobile data is turned on go through the settings on your device and disable any apps that might be using mobile data in the background.
