133
Discussion topic: My Piggybank won’t allow me to roll over data into my phone
This message was authored by Sscc1234 This message was authored by: Sscc1234
I have rolled data from piggy bank it has took off my piggy bank but not on my account still
I have rolled data to my phone from my piggy bank but still not showing on my account after few hours
This message was authored by Littlemissnat This message was authored by: Littlemissnat
Re: I have rolled data from piggy bank it has took off my piggy bank but not on my account still
The same has happened to me.  Looking for an answer
This message was authored by alun63 This message was authored by: alun63
trying to roll data to my sim it comes off the amount in bank but doesn't go onto my sim
im currently abroad i have no data cap and i use the roaming passport when i try to roll data from my bank it reduces the amount i have left but does not add it to my sim
This message was authored by Sarah+N This message was authored by: Sarah+N
Sky Piggy Bank
I have transferred data to my mobile but still says I have no data.  Any ideas why?  Piggybank has gone down but no sign of the data!
This message was authored by AngryData This message was authored by: AngryData
Re: Sky Piggy Bank
Same with me, I have rolled 4gb of data and still showing as 0 available.
I have looked all over the site and tried to use the virtual assistant but just sends me back to piggybank page
This message was authored by 63johnw This message was authored by: 63johnw
Re: Sky Piggy Bank
Hi @Sarah+N  and @AngryData  call sky free on 150 and ask them to look into it, that will be your quickest option to get a response from sky.
If someone has helped give them a thumbs up.
If their answer solved your issue mark it as the correct answer.
I won’t respond to direct messages so please post any problems on the forum.
Give it 24 hours to see what happens but don't roll it again it it still hasn't shown up after that but post back on here instead.
Re: trying to roll data to my sim it comes off the amount in bank but doesn't go onto my sim
There are sometimes be a delay in the data showing up so see what happens if you leave it for 24 hours.
This message was authored by Harryz1600 This message was authored by: Harryz1600
Rolling data piggy bank
Hello can anyone help, each month I roll back data and share it across 4 different sims which all link to me , today I did as normal to share the data for the month but has not gone over. I have enough data in my account so that's not the problem
This message was authored by Nikifos This message was authored by: Nikifos
Piggy bank not updating phone
Just tried to update my phone twice with data from my piggy bank. I have an email confirming data rolled over and the total has reduced but still 0 data on my phone and no 3/4G signal ?
Re: Piggy bank not updating phone
Hi @Nikifos  if you have a quick scan of this forum you will see over the last couple of hours there are many similar reports so sky must be having an issue. You could try calling on 150.
Re: Rolling data piggy bank
Hi @Harryz1600  if you have a quick scan of this forum you will see over the last couple of hours there are many similar reports so sky must be having an issue. You could try calling on 150.
Thank you, I'm trying but can't get through
How do I get through via messenger ?
tried and failed to get through a few times - I don't have WiFi where I am and now no 4G 😡
This message was authored by dalgetybay This message was authored by: dalgetybay
Piggybank data not rolling over
I am rolling over data to one of sims, the data is leaving the piggybank. but is not being added to the SIM.  Are there any techinocal issues with this at the moment?
