Discussion topic: Mobile ordering issue
Message posted on 29 Jan 2025 06:52 PM
Hi,
I've been trying to order a mobile phone on the Sky site and it keeps failing when i get to the final part of the process. 'Technical error, its not you its us'.
Tried it on both my sky app and webpage, same happens on both. anybody else heard of this?
Regards,
Darren
Message posted on 29 Jan 2025 06:54 PM
Re: Mobile ordering issue
Give Sky a call and an agent can place an order for you.
Message posted on 29 Jan 2025 07:14 PM
There is that option, although I'm not big fan of waiting in call centre queues. A little embarrassing Sky have this issue 2 days running (If it is their issue). It's probably costing them a fortune in lost sales...
Message posted on 29 Jan 2025 08:53 PM
I'm having the same issue
Surely sky sees these posts and reply with a solution to the issue
Message posted on 29 Jan 2025 08:55 PM
@Deeanne
If you’re not already aware this is a customer helps customer forum and you aren’t contacting Sky Customer Services on here so you're unlikely to get a response from them.
If clearing cache etc doesn't work then calling is the option.
Message posted on 12 Apr 2025 10:23 PM
i haver had this issue for 3 months now, number of calls to customer services with no solution just fobbed off that will be looked into and contacted.
ive missed out of a couple deals because of this.
Message posted on 09 Dec 2025 02:22 PM
I had the same issue for the last 24 hrs....the issue appears to be the order getting stuck in cache and going in a death loop when you try again.. The simple solution that worked for me on my iPhone was to delete the app and reinstall- then my order went through first time. Attached the how to link for iPhone and Android users
