Discussion topic: Mobile data not working
Message posted on 04 Aug 2024 01:08 AM
Re: Mobile signal problems
Hi thanks for your response, I checked the link you sent me, it just comes up with sky's bog standard, so we don't have to do anything, "our networks can be extremely busy !!!!" blah blah blah etc.!!!!
what at 3am 4am 5am come on sky, get Ur act sorted!!!!!!
I still have the problem,, 2 weeks now????????
Message posted on 04 Aug 2024 09:48 AM
Data not working
Message posted on 04 Aug 2024 09:53 AM
Re: Data not working
Does any mast issues show here for you:
https://www.sky.com/help/servicestatus/your-services/mobile
Message posted on 04 Aug 2024 09:59 AM
@caesarome it says there is no mast issues and I've tried everything I got told to do nut nothing works
Message posted on 04 Aug 2024 10:04 AM
What have you tried ?
Message posted on 04 Aug 2024 01:15 PM
I've tried switching phone off nd on I went into settings and reset network settings I've switched airplane mode off nd on and got sky to send settings but nothing worked.
Message posted on 05 Aug 2024 09:01 AM
Re: 4G Not working despite having signal and data
There was a mast issue last Monday (29/07) which apparently got fixed, however a week later and we still can't use our data. Again have tried literally everything possible but no luck
Message posted on 17 Sep 2024 05:39 PM
Re: Mobile data not working
I continually have to go into my settings on my iPhone and switch my mobile data from 4G to 3G only in order to get an Internet connection while I'm out and about. There are so many areas near me where my sky signal seems to offer me two or three bars of 4G but just will not connect to anything at all. However when I switch in my settings to 3G everything is okay I'll be it a bit slower. Very strange
Message posted on 28 Sep 2024 03:54 PM
My data never works when I go into Chelmsford town centre, just there for a couple of hours nothing, it says 4G / 5G but nothing loads.
The early bird catches the worm but the second mouse gets the cheese!
Message posted on 20 Jan 2025 11:13 AM
Since last 4 days I am not been able to use my mobile data, I have restarted my device in our SIM card. But not still working
